Home / Main Index / General Option |
Select the [Option/Option] menu to start this Global Option dialog box.
Start BestSync when windows starts.
If this option is checked, BestSync starts when the Windows OS starts.
This option create a task schedule in Windows Task Scheduler to start BestSync in the highest priority when an user logon.
Run as administrator.
When this option is checked, BestSync is started by the administrator privilege by the Windows Task Scheduler at the root time.
Start as a task tray icon.
When BestSync is started, it is minimized as the
icon in the task tray.
Check for new version on the website.
If this option is checked, BestSync will check the website for new version at the start time. If new version is available on the web, BestSync will popup a dialog box to display the new version information and download address. If you doe not response the dialog box, it will be closed automatically in 10 seconds.
When in the state of task tray icon, show the notify window.
When BestSync is minimized as a task tray icon, and some tasks are scheduled to start, if this check box is checked, the notification window like the above picture shows to display the progress and will fade out when finished. If this check box is not checked, the notification windows will not show, and the tray icon will be an animation icon.
Run scheduled task sequentially (Except the real-time task).
If this check box is checked, the tasks started by the schedule will be run one by one, i.e, the later started task will not be run until the previous task completes. Please note, if the task is started by the menu or toolbar button, it is run at once.
Save plain xml setting file (.tfsf)
When this option is enabled, when saving the task settings, in addition to saving the encrypted settings, a clear text xml format setting file (.tfsf) is also saved, so that you can directly modify the settings using editing software. After modifying the settings, rename (.tfsf) to (.xfsf) and restart the program to recall the modified settings.
