Home / Main Index / General Option |
Select the [Option/Option] menu to start this Global Option dialog box.
Tool to view file difference: (SyncDiff.exe %1 %2)
Set the comparing tool to view difference of two files or two folders. Set the full path of the tool with two parameters %1 and %2, means the file1 and file2, or folder1 and folder2.
If WinMerge tool is installed in the system, BestSync will use WinMerge automatically.
