Home / Main Index / General Option |
Select the [Option/Option] menu to start this Global Option dialog box.
Show shutdown options in the main window.
If this check box is checked, "Shutdown when all the tasks complete" and "Confirm: Really shutdown?" option will be shown on the bottom of the main window, to let you to select to shutdown computer when all the task complete.
Hide the "Start" button in the main toolbar.
If this check box is checked, the "Start" toolbar button in the main window will be hide. This option prevents user from operating the "Start" button by mistake.
Move task to the top of the list if it is started manually.
If this check box is checked, the task item will be moved to the top of the list if it is started by a push of toolbar icon or selection of a menu. If this check box is not checked, the task item will not be moved.
Select the columns to be shown in the Task List
Tick the column name if you want to show it in the Task List of the Main Window. You must tick one or two in "Task Overview" and "Task Description".
