(1). Select "Microsoft OneDrive" in the "File System" list.
(2). Setup the parameters for connecting to the Microsoft OneDrive.
If you have not got an account, you can click "Sign in OneDrive, 5GB online storage for free" link to apply a Microsoft Account.
Use http Proxy:
If the local computer is behind a firewall or NAT, usually the computer needs the proxy to connect to the OneDrive.
(3). After set up the parameters above, press "OAuth2 Login" button.
The "OAuth2 Login" dialogbox pops up, input Microsoft Account and password to login OneDrive, allow BestSync to access your OneDrive.
If login OneDrive successfully, Access granted, please press "Close" button to end the dialogbox. is displayed in the dialogbox.
Press "Close" button to close the dialogbox.
*In case you see "Please install WebView2 Runtime" message on the screen, please download and install the WebView2 runtime first. Here is the microsoft link for download WebView2
https://developer.microsoft.com/en-us/microsoft-edge/webview2/(4). Press "Go" button to refresh the file tree.
BestSync lists all the folders in OneDrive, and display the folders in the file tree.
The log window below the file tree logs all the commands sent to the OneDrive, and responses from the OneDrive.
If the connection between BestSync and OneDrive can not be established successfully, please check the log.(5). Select the folder in the file tree for synchronization.
(6). Click "OK"button to end the dialog box
