How to reboot the remote server after WebDAV synchronization?
I try to sync from Windows to WebDAV folder on Androids. Everything works as expected. However, After sync finish I want to reboot the remote android device. Can you share step by step how to use this feature; apps need to be install on the android devices and .bat
file. I only need to reboot the device after sync complete.
Re: How to reboot the remote server after WebDAV synchronization?
For rebooting the remote device after the WebDAV synchronization.
You need to do the following:
1. Implement a HTTP command in the remote device, like:
http://remote_ip/reboot.php
2. In the Task setting of BestSync, Specify the above URL in “Application”/ ” Application or Sync Task to run after synchronization”, like the following screen:
http://user:password@remote_ip/reboot.php
[attachment=0]RebootDAV.png[/attachment]
user:password is the user account of the WebDAV server(if necessary). You can skip the account, BestSync will use the account of the WebDAV server.
