Hello Support,
I have jobs scheduled running every 5 or 15 minutes; sometime I found that a few jobs under running tab and status as "queue to synchornizing"; and they actually stopped. I had to stop those jobs to clear them from the Running tab. then next schedule time they started to run.
My schedule for those jobs:
Start task when this application starts
service sync: Run task as windows service (need not user login)
Designate a schedule every 5/15 minutes
Please advise.
Regards & Thanks
Sherry
Bug: BestSync 2014 job stopped sync under the running tab
Re: Bug: BestSync 2014 job stopped sync under the running ta
Have you confirmed that the following option (Option/Option menu) is NOT checked?
[attachment=0]RunSeq.png[/attachment]
- Run Task sequentially
- RunSeq.png (17.7 KiB) Viewed 9475 times
The mentioned option is checked at the moment. Do I need it NOT checked?
Regards & Thanks
Sherry
Regards & Thanks
Sherry
If you want the tasks run immediately after being started, please uncheck the "sequential" option.
