interested in buying BestSync
yawobeng
Post by yawobeng »
I am interested in buying BestSync but I need to know if it can do what I want and having instructions on how to do exactly what I want. This is very important because i dont want to loose data
I have a folder on my local computer called "Outputs" that I want to sync with my amazon s3 bucket called "Videos". So Outputs --> "Videos"
When a file is placed in "Outputs" folder, I want it to go to "Videos" bucket then delete from "Outputs" folder after file is 3 days old.
If I delete a file that is less than 3 days old from "Outputs" folder. It should automatically delete from "Videos" bucket.
My questions are:
1) Can this be done?
2) if yes, How can this be done exactly? running in the background of my server?
3)What license do I need to accomplish this?
Re: interested in buying BestSync
BestSync can do exactly what you want.
You can set the options like the following:
1. Files older that 3 days will be deleted.
If a file is deleted, it will be deleted from AmazonS3 less than 10 minutes.
[attachment=0]WzScheduleMinute.png[/attachment]
2. If you need the task run in background in the server, please select “Service Sync” in “Schedule” TAB.
[attachment=1]WzDelete3Days.png[/attachment]
3. You need the Ultimate License to synchronize with Amazon S3.
Wizard Delete Old Files
Run As Service
Run As Service
yawobeng
Post by yawobeng »
This software is buggy or something. I did exactly what you said. Nothing is synchronizing
We have confirmed that there is problem when synchronize with AmazonS3 as Windows Service.
At the current stage, please uncheck the "Service Sync: Run Task as Windows Service option" to avoid the problem.
