Hi Jean-Pierre,
I've installed BestSync 2013 (English Version Ver8.0.0.3, 32Bit) on three different Windows 7 Pro x64 machines. This was an upgrade for all three machines from v7.3.27.
Two out of the three machines seem to be working fine. However, BestSync is crashing on the third machine. See the three attachments for details.
I am able to avoid the crash on the third machine by turning off BestSync's backup option. On the first two machines, BestSync ran OK with the backup feature fully enabled.
Have I provided enough information for you to debug and fix this problem?
Regards, Jeff
BestSync 2013 Crashing with Backups Turned On
Re: BestSync 2013 Crashing with Backups Turned On
We have built a new version of BestSync 2013 (Ver 8.0.04), please check on the new version to see if the problem has been resolved.
32 Bit version:
http://www.risefly.com/2013/BestSyncSetup.msi
64 Bit version:
http://www.risefly.com/2013/BestSyncSetupX64.msi
32 Bit version:
64 Bit version:
I downloaded and installed Ver 8.0.04. I'm still having the same problem on the same workstation. Here's the crash data:
Problem signature:
Problem Event Name: APPCRASH
Application Name: bestsyncapp.exe
Application Version: 8.0.0.4
Application Timestamp: 50cc4095
Fault Module Name: ntdll.dll
Fault Module Version: 6.1.7601.17725
Fault Module Timestamp: 4ec49b8f
Exception Code: c0000005
Exception Offset: 000222b2
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Problem signature:
Locale ID: 1033
Could you please export the task setting to a file and send it to risefly(a)risefly.com?
So we can debug it.
So we can debug it.
Jean-Pierre,
As you requested, I just emailed you the exported task. FYI, I carefully edited the exported task to remove passwords, username, and ftp server. I hope that doesn't cause a problem for your debugging. Let me know.
Also, while I've been working around the bug, I've repeatedly toggled the backup option on and off. I've noticed that whenever I enable or disabled the backup option (the top check-box on the Backup tab) BestSync "forgets" some of the other backup settings (i.e. the Backup Folder). Will you please enhance BestSync so that it will always remember all of the backup settings whenever the backup enable option is toggled? See the attachment.
- 2012-12-16_140358.png (23.68 KiB) Viewed 19240 times
Thank you for report this problem. It has been fixed, please try the new version 8.0.0.6.
32 Bit version:
64 Bit version:
The problem happened when backup FTP file and network error happened during downloading the file.
32 Bit version:
64 Bit version:
> version 8.0.0.6.
Confirmed! This fixed the problem for me. Thank you!
> version 8.0.0.6.
I have the same problem using Version 8.0.0.7 (German & Ultimate Edition) on a Windows Server 2008 64bit system (without R2).
I only made a simple task: backup data without compression or anything else to my FTP-Server. After pressing the start button the job begins and crashes.
During configuring the task, the FTP Server test works fine - also if I use the preview.
The task works fine if I use a local folder <- perhaps this is useful!?
Could you please help me resolving this problem?
I found out something new:
Using SFTP works fine without any crashes.
Hello bellhawk,
I have tested this problem, but can not recreate the problem.
Could you please export the task setting to a file, and send it to risefly(a)risefly.com?
Thank you.
Thank you.
