BestSync scans all the files in all folders (which takes some time...) even though I have configured several folders to be excluded.
Am I doing something wrong or is this a bug or is it by design ?
thanks for help
steve
Scanning-Bug ?
Re: Scanning-Bug ?
If sub-folders are excluded form synchronizing by "Exclude or include" setting, they will also be excluded from the synchronization.
How do you setup the excluding setting?
Re: Scanning-Bug ?
Yes, the excluded folders are not synchronized, but they are scanned - which is unnecessary and takes a long if there are a lot of files in these folders.
I'm doing it the 'normal' way (see the screenshot)
In the screenshot of the preview you can see that f.i. the 'metadata'-folders are scanned, but not synchronized.
- SetupSyncAndPreview.jpg (217.56 KiB) Viewed 7850 times
Re: Scanning-Bug ?
Thank you for reporting this problem, we'll investigate this problem and try to fix it in the new version.
