Winsock error 0x0000271e when speed limit is enabled
jmendiburu
Post by jmendiburu »
Dear Sirs,
I'm having problems with Bestsync when syncing a FTP site to a local USB drive, but only when speed limits are enabled.
Error message is:
winsock:Receive::Error.:error:(0x0000271e):El sistema detectó una dirección de puntero no válida al intentar utilizar un argumento de puntero en una llamada.
Please find attached log files for both cases, when speed limits are enabled and when not.
Thank you
Logs.zip
(5.89 KiB) Downloaded 1419 times
Re: Winsock error 0x0000271e when speed limit is enabled
We have made slightly modification related to the speed limitation control.
Please download the new BestSync 2018 Ver 13.0.1.4 to see if the problem can be resolved.
And please confirm the speed limitation settings to see if you have set to to low speed such as 0 K/s etc.
jmendiburu
I'm currently using BestSync 2018 Ver 13.0.1.4, so this doesn't help.
Speed limit is set at 12500 KBytes.
Please download and install Bestsync again, because we have changed a little related to the speed limitation thought the version number has not been changed.
